It depends on your hot water source.
We’ve just moved into a new house that’s got quite a good combi boiler and very good mains water pressure.
As a stopgap, until I re-do the bathroom I replaced the horrid electric shower with a thermostatic bar mixer that combines a bath filler with a shower. It is so good, even I have to turn down both the pressure and the temperature. You get a real hot soaking. I was surprised how good it was and I fit bathrooms as part of my work.
I love a good shower and I cannot bear the electric ones that run off the cold feed. No matter how many amps. The performance drops off massively in winter when the temperature of the water coming through the ground is really cold and you need it really hot to counter a freezing bathroom. All you get is a dribble.
If you have a cylinder for the hot water you will need a pump to get a good shower but you risk emptying the tank. However, a big enough tank and powerful enough pump will usually give you the best shower.
The shower head itself plays a big part in the quality too. And so does having a wide bore hose.
