Answer is simple: no
With the Apollo You get a heavy fork that has no damping and will either explode or just stop working completely after the first rain, however even if not working it will still weight a lot. Single wall rims, probably not the strongest as well. Like others pointed out 7 speed bike, shimano equipped, most of it is Tourney so lowest group. Some mud etc and it will stop working. The disc brakes are also a fashion accessory on it and I would check whether You can get spare pads for them or adjust the brakes in any way.
Carrera makes good bikes and if You are on a budget than they are worth a look. You are on a budget, get a bike that has normal V brakes and a rigid fork. Savings in those areas will generally mean better frame and better equipment. However if You are sold on the looks and don't want to listen to some good advice than You will soon regret it. The bike will probably start falling to bits after some awsum offroad action and if You don't know or don't have the tools to change parts/repair it it will cost You almost as much for paying Your LBS to do it.
The Diamondback is a good choice. Try Decathlon, they do good bikes at a good price:
Rockrider 5.2
Or Carrera Vengeance from Halfords
It's a bit more than Your budget but You will save on the future repair bills and trips to the LBS.
