Viewing 8 posts - 1 through 8 (of 8 total)
  • What do I need to lengthen my XTR disc brake cable?
  • damitamit
    What brake cable (or kit) do I need to do this?
    I will have to bleed it right?
    highclimber
    if its mechanical it wont need bleeding but I dont think there is a mechanical XTR brake so you will need longer hoses and some fluid and you will have to bleed it
    cynic-al
    Yes, longer hose (surprise surprise!) and bleeding.
    Taff
    CLICKY – Something like this is for you want to completely replace alternatively most hose is availble for about £6-7 per metre.
    As for oil just got to local motor factor and get some dot 4 or dot 5.1 brake fluid
    TandemJeremy
    shimano use mineral oil not dot fluid so don't use dot fluid – you will ruin the brakes
    MSP
    and you will need a little yellow goodridge tab for extra too cool for school points.
    Dibbs
    You'll probably need a new olive and insert too.
    foxyrider
    Do you mean hose?
    If you do then get some compatable goodridge hoses and a small bottle of mineral oil from CRC and the like?
    http://www.chainreactioncycles.com/Models.aspx?ModelID=2938 – goodridge hose
    http://www.chainreactioncycles.com/Models.aspx?ModelID=20424 – connectors – not cheap – check the fit your version of XTR?
    http://www.chainreactioncycles.com/Models.aspx?ModelID=29899 – mineral oil
The topic ‘What do I need to lengthen my XTR disc brake cable?’ is closed to new replies.
