Viewing 11 posts - 1 through 11 (of 11 total)
  • What CX chainset?
  • dobo
    Was just going to go for a shimano ultegra or dura chainset and a mix of other ultegra and 105 parts but wondered if theres anything else i should consider?
    I'm also still considering a single rather than double ring setup, do these work fine with 10 speed setups? i've used them 1×9 on the mtb before
    simondbarnes
    I'm using a Shimano R700 compact, before that had a TA Zephyr light compact (which is probably for sale if anyone wants it!)
    clubber
    There's a whole article on cyclingnews.com about 1×10
    I just use a standard road compact with 34/50
    Leigh
    i have been running sigle ring for the last 7 years with no problem on 9 or 10 dura ace. on 42 with spooky carbon guides with 12-25 cassettes
    dobo
    thanks for the cyclingnews 1×10 info
    so tempted to buy 7900 from planetx as the price seems good and run it 1×10
    dobo
    anyone use bar end shifters on there 1×10, or is sti still the way to go?
    if using barcons? what brake levers would be best?
    oldgit
    Not many people using bar end shifters. If youre starting from scratch STI/Ergo has to be the way. I can think of a few courses where barcons would be a mare.
    dobo
    cheers for the info, sti feel a bit weird to me as i ride mtb mostly, never used barcons.
    so for 1×10 do people still use an sti for both brakes or do they buy some drop bar brake fake sti?
    leggyblonde
    strip the LH sti
    dobo
    hmm
    so i can but a non matching LH drop bar lever (which ones best)?
    or i can buy a LH sti and strip it which is expensive but will match the RHS
    hmm
    oldgit
    Non matching L/H lever like this bloke used to do
The topic ‘What CX chainset?’ is closed to new replies.
