Viewing 16 posts - 1 through 16 (of 16 total)
  • What cable cutters?
  • uwe-r
    What do i need for a nice clean cut on my new cables? Big beast cutters or small and sharp?
    wysiwyg
    On one. Or dremel
    Northwind
    Better than Park:
    http://www.ebay.co.uk/itm/DRAPER-EXPERT-190MM-WIRE-ROPE-OR-SPRING-WIRE-CUTTER-/271188273055?pt=UK_Hand_Tools_Equipment&hash=item3f2414a79f
    If you’re a bike-specific person, then Superstar sell a set that are pretty decent- they work well on day one but blunt a little too easily. Also better than Park though.
    pembo6
    Dremel or angle grinder with fine cutting disk.
    If u do use a dremel, make sure it is on full power. U want it to cut through fast for a perfect cut.
    And I find that if u place a block of soft wood behind the cable inner or outer it leaves a perfect finish on the cut.
    zbonty
    You can easily go big and blunt if you heat the cable with a lighter for a few seconds. Good clean cut ime. Crimp the cap on. Go ride!
    No way would i be bother to get the dremel out and fit a little cutting wheel to do it.
    jim25
    my park cutters are awesome
    shortcut
    The right tool for the job is the tool designed for the job.
    So some cable cutters would seem logical.
    orangeboy
    Knipex
    freeagent
    Knippex or Maun would be the choice of professionals in the real world. Park are overpriced and not as good.
    AndyF1
    Felco.
    Kuco
    Got park and shimano both do a decent job.
    bristolbikeproject
    The Drapers are good. Best for the money. The Predro’s are great, but not really worth £30. The Parktool are hit and miss. We’ve had a load of them fail and had to be returned. They work ok when they work.
    bowser538
    Superstar components 13.99.
    never had a problem.
    johnnystorm
    Another happy superstar user here. 🙂
    uwe-r
    Thanks all, a real slow burner this tread. A lot of these look suspiciously similar. I think I know what I need now.
    P.s. having gone for a ride this morning I did need to butcher the new cables with some rusty old pliers. It’s more of a recovery job now.
    shadowrider
    I use cable cutters at work everyday, I have found Lindstrom cutters to be the best I’ve owned, better than knipex. They were quite expensive tho, but my latest pair have lasted me about 5 years and they are still cutting as well as when I purchased them
The topic ‘What cable cutters?’ is closed to new replies.
