Another Spitfire fan/recommendation here.
I’ve had mine for 18 months now, currently running 160mm pikes (26″), superstar carbon wheels with Spec butcher/purg grid tyres.
I have a second set of wheels (flows on ProIIs) setup with dual ply tyres which I put on for uplift days and used for a week in Morzine this summer.
I’ve had mine in the 66 degree setting since I first got it – this matched the static HA form my blur – pedal strike was an issue so I switched to 165mm cranks. If you’re transferring a 650b buildkit over, this should be less of an issue as the BB is 12mm higher.
The suspension is very active, I regularly use the climb switch on the ccdb inline shock when climbing, but very progressive too, so nice and supple over choppy terrain but keeps plenty in reserve for the big hits, I’ve only felt it properly bottom out once, when I came up short on a jump and caught the upslope, the resulting impact was hard enough to bend the saddle rails and make my eyes water 😯
I’ve got a -2 degree angleset waiting to be fitted. I’m also hoping to experiment with a change to 650b wheels and fork this year, mainly for ground clearance reasons but also to see if the change in wheelsize really will bring my rides to life or whatever marketing junk it is this week.
V2 frames seem to be going for 6-700 depending on condition/shock, I think there’s one in the classifieds now.
