For got to say – I got mine on the Halfords bike to work scheme….
The advantage of going Dolan is you can swap and choose bits in the check out, so you can change stem length, crank length, new wheels, tyres etc.
And you can pay with the Halfords voucher and get it sent to your local store. More info here:
http://www.dolan-bikes.com/cycle-to-work-schemes/
Just watch the sizing – I’m 5’10”, 34″ inside leg, and went with a large (52cm) after speaking to them, found it too stretched and now run with a 80mm stem (short for road bikes) which is just fine. Should have gone with the 48cm ‘medium’ with a 110mm stem.
