Experience of an unfit cyclist! 😆
Milngavie to the bottom of the descent down to the foot of conic hill, cycleable.
Conic hill, push up, pretty steep on the way back down, I got to the stairs(I think you can go left and just fire down the grass, not sure though, couldn’t be arsed doing it again.) I’d 1 otb moment and I don’t think I made it down the whole thing.
Up to rowarrdennen is generally alright, if yer gubbed, the upppy down nature can be a pain.
beyond this, haven’t done it, don’t fancy the north LL side at all going by reports.
I’ve done the train up to tyndrum and done the last bit though. Which is fine. (should be fine to start from the drovers as far as I know though.)
tyndrum to bridge or orchy, all cyclable
Up to mam carraigh is cycable, the down is excellent
Over rannoch moor to kingshouse is easy enough, though watch yourself, I did come off at one point due to not paying attention properly!
kingshouse along is fine, but up the devils staircase is a push, down the devils staircase is good, but can be a bit rough in places. fire road end is a bit of a disappointment.
Push up from kinlochleven is a killer, but there’s an alternative fireroad route that is easier to cycle I think.
From the top of the kinlochleven to the split of choice of road or uppy downy to FW is all good an easy enough, most scenic bit for me, loved it in there more than the other bits to be honest, cracking valley.
after split, it’s a bit uppy down, good, but if you are gubbed by this stage there’s some pushing. Downhill in to glen nevis was all fireroad for me, but there were diversions in place, so I don’t know if I missed some better downhills.
Most of it is cyclable of the bits I’ve done, really depends on your fitness. Less fitness = more pushing!
