Viewing 23 posts - 1 through 23 (of 23 total)
  • Weightists – a challenge for you…
  • Kryton57
    I keep coming up with different answers using the web only, so let’s see if we can get 2 people to match. Right, ready? Well then, what’s the weight of my bike:
    enigma ego Ti 17.5
    2012 XT 2 x 10 groupset 28/40 and 34/11 with ice tech 160mm rotors
    M520 pedals
    2012 Sid RLT Dual air steerer 200mm QR
    2012 American Classic XC 26″ wheel set with AC qr’s
    F Nobby nic 2.25, Rear 2.1
    enigma carbon seat posts
    Enigma ti railed saddle
    Thompson 90mm 6 degree stem
    Raceface dues XC bar 2012
    Xt cables and outers
    Enigma headset
    Salsa qr
    I’ll check back in the morning and see how many different answers there are 😀
    crikey
    Why don’t you just weigh it? 🙄
    scaredypants
    19lb – or are you using proper scales ?
    DrP
    Four?
    DrP
    fasthaggis
    The most important weight is the big lump sitting on it 🙂
    Kryton57
    Crkey – I only have bathroom scales. Scaredypants – I got 19lbs too but it feels much heavier than that…..
    Fast haggis – I’ve lost 13lbs sin July and still going…
    radoggair
    no way 19lbs, scales are way off. Frame is probably 1.3 -1.4 kg, heavy forks, rotors , stem, bar , groupset etc. I would say more like 23lbs
    aracer
    I’ll bid 24lbs. No way is that anywhere near 19.
    beej
    Grips?
    Rim tape?
    Which model of Nobby Nics?
    I’ll guess it’s the weight of a medium badger, male.
    Kryton57
    Ah. Renthal Kevlar grips, Stan’s yellow tape and non tlr Nics, triple nano Evo.
    taxi25
    Not seeing 19lbs, more like 21 and a bit of change.
    scaredypants
    (should stress, my 19lb was a joke)
    /edinburgh
    maxtorque
    If you’re in Space the weight is zero.
    Northwind
    Low 20s, daft to try and get closer than that tbh but if I had to, I’d say 23lbs.
    danielgroves
    Sort of. You’d have a tiny (yes, negligible) weight if you are within the gravitational pull of a planet/star/astroid/comet/lump of whatever/lost aliens 😉
    theonlywayisup
    22.75lbs … or sensibly light. I have something similar – just get out and ride it and don’t worry about a few lbs 🙂
    jameso
    ~23lbs also, or on my scales, ‘wgas there’s nothing heavy on it and some stuff may need to be beefed up’
    19lbs, no chance )
    epicyclo
    The number is always 42.
    The only problem is finding a suitable unit for the number.
    DanW
    This… or maybe this
    I’ll bid 24lbs.
    Definitely this
    mikewsmith
    32lb
    tubes? Tubeless? how many cups of Stans?
    Kryton57
    Tut. It’s not 32lb.Tubeless, 1.5 cups of Stan’s in each tyre
    njee20
    23-24 seems about right
    Kryton57
    Njee if you just happened to be carrying your scales later this month… 😀
The topic ‘Weightists – a challenge for you…’ is closed to new replies.
