I’ve got a WordPress website that i setup recently. i’m a graphic designer (and not a coder, hence WordPress), and i’m using it as a portfolio. It works fine with Firefox and Safari, but does not work properly with IE on a PC. The problem is that the homepage slideshow is not showing up – it should simply be a sequence of 4 images fading from one to the next. It just shows a static ‘problem image’ box. There are also ‘problem images’ above the thumbnails on the homepage.
Can anyone help? Or does anyone know of any web forums where I might get some advice.
Here’s the address: http://www.wallflowercreative.co.uk
This is definitely not an advert. It’s a genuine call for help. Thanks for reading.
