Viewing 5 posts - 1 through 5 (of 5 total)
  • Wear on frame
  • jpacey
    My left (rear) foot has rubbed a patch of paint off the rear triangle of my frame. Aesthetically this doesn’t bother me but I’ve just read in MBR that it could wear a hole thru the aluminium! Is this really possible and will heli tape protect it?
    James
    njee20
    Eventually, if you keep doing it then you could. You’d have to try very hard, and be bloody unlucky though.
    Helicopter tape will help, but that’s softer than alu – so you’ll wear through that too.
    iolo
    Or slice an inch off your foot
    Gary_M
    Yes but when it does wear through you can just replace it – the heli tape not the chainstay 🙂
    I had some wear on the chainstay on my commuter, got a chainstay protector made to a custom size to cover it and its been fine for the past year.
    jpacey
    Cheers. Hadn’t thought of a protector I’ll whack a bit of inner tube on to match the other side .
The topic ‘Wear on frame’ is closed to new replies.
