The usual advice is the opposite to that – higher speeds mean more air cooling and more ‘free’ braking due to wind resistance.
Dragging results in more heat build up in the wheel and less ability to cool it.
But how much cooling do you want and need? It’s all about managing peak temperatures with carbon. Above a certain temperature the glue is affected and therefore rim life is. Below that threshold the glue is fine, so as long as you manage your rim temps then you can drag your brake as long as you like. Mechanical wearing of the rim then becomes the issue that determines rim life just as with alloy rims.
At any given applied brake force a certain amount of energy is imparted into the rim. The temperature that ‘builds up’ depends on how well you can cool the rim. At relatively light braking forces the temperature is quite cool and constant i.e. it doesn’t build up and continue to increase. At very heavy braking forces you might not be able to cool quickly enough so rim temps might very well continue to rise and build up.
The aerodynamic braking effect is marginal. In the same way as you need more and more power to get to higher speeds because drag increases to the square of speed, when it comes to braking the same effect applies – the drag reduces to the square of speed, so aerodynamic drag as an aid to braking is not very effective other than at very high speeds. As soon as you slow down the drag effect drops off very very quickly.
Old rules may not apply. You might need to choose between descending more slowly and carefully to manage rim temps and preserve rim life, or descending quickly and brake harder, but eat up rim life more quickly.
But it’s all academic. For the majority of us who are not hitting the Alpine descents week in week out, I suspect it’s not an issue unless you’re routinely a really heavy braker. And for those of us who do hit the Alpine descents how many of us are really hitting them like a Pro? I don’t, I’m like an old woman.
