My dad’s water supply is pumped storage from a natural spring, stored in a 20,000 gallon tank and gravity fed to the house.
He noticed that the pump which refills the tank had been running at maximum capacity for a few weeks, and concerned he had a leak, walked the length of the pipe (part of which runs over his neighbours’ land.
He was somewhat surprised to see that both had tapped into the pipe and were using it for livestock (cattle and over a hundred sheep).
He called me tonight absolutely apoplectic and I talked him into sleeping on it, as opposed to going around directly to talk to the neighbours, whom he doesn’t know well.
He reckons, at an absolute minimum based on known pump capacity, he’s lost about 100,000 litres of fresh water from a fairly limited supply.
On the grand scheme of things, is this the sort of thing that it would be sensible to give the police a call about? I suspect if you did the same thing to United Utilities they wouldn’t sit idly on it.
I’m quite for sending them a bill based on the current price of Evian in a motorway service station…
