Its for a mess around / jump bike so not arsed about weight etc..
Must have disc brake mounts, be QR and 100mm suspension corrected
I think that translates to 445mm a-c length.
I've got some but I don't know if their 100mm suspension corrected or not. Any way to check?
Got some Kinesis Pro ones that are the older version of these: http://www.chainreactioncycles.com/Models.aspx?ModelID=49590
Paint is a bit tatty but completely function and actually quite light and very well built as they are Kinesis. Has lugs for V brake mounts but I was using them with discs.
Steerer is about 200mm and definitely 100mm corrected at 440-445mm (hard to measure exact).
£24 + postage? (off to check but I think it's about £4)
Zempy, the Kinesis any good to you? Just offered to buy some wheels so would be good to get some cash to pay for em
andyl, Thanks but no thanks looking for somthing a bit more dirt jumpy.
Cheers anyway
Hi,
I have some black steel ones that I are about 430mm crown to axle. That is about 100mm suspension territory I think. You can have them for £15 posted at they are wee bit tatty. They have disc mounts.
Cheers,
Dave
Davervan,
I already have a pair of salsa 430mm (they equate to 85mm travel) there ok but they make the head angle on the frame too steep. I really need some 445mm a-c ones. Thanks anyway.
Some of the surley instigator ones would be ideal.
You must log in to post.
