Viewing 11 posts - 1 through 11 (of 11 total)
  • wall shelf bracket help – to support 50cm deep – gf suitable fixings
  • towzer
    hi
    after making a turntable shelf – gf likes neat, stylish etc things, I want something that will reliably support a fairly heavy 50cm deep turntable (so shelf 50cm x 50 cm) (to brick wall)
    trouble is wall mounts need to be neat, stylish and she likes glass and for style reasons the large, functionally effective, cheap large L shaped brackets are out ……..
    any ideas ?
    Thanks
    hammyuk
    Nice big heavy duty ones from Wickes….
    And either MTFU or get a new GF….
    piedidiformaggio
    just get her to hold it if she’s that fussy
    hammyuk
    piedi di formaggio – Member
    And the shelf….
    spicystealth
    Love all the comments above
    Quick search on google
    50×45 shelf with support for AV equipment
    Not sure if stylish enough though
    http://www.chaseavdirect.co.uk/unicol-avp2-avecta-optional-metal-shelf-45-x-55cm.html
    spicystealth
    Oooppps my bad it looks like it slots in to a fitting of some sort
    66deg
    Quick and easy GF wall fixing.
    towzer
    thanks guys
    off to get some duct tape …………………
    BigJohn
    I’ve used these before and they’re OK if the wall is sound. If there’s a gap between the plasterboard and the brick I wouldn’t use them though.
    JohnJohn
    You’re into brick so you could do a floating type bracket – screw threaded rod into drop-in anchors then depending on the thickness of your shelf either drill holes to slot onto the rods, or put a couple of o-rings on each rod and sit shelf on top?
The topic ‘wall shelf bracket help – to support 50cm deep – gf suitable fixings’ is closed to new replies.
