Thanks all. Spent a good hour or so in B&Q today having a look at options. I don’t fancy using a system that transmits any of the the weight to the plasterboard. Its a heavy TV because its a Plasma screen, so much heavier than an LCD/LED TV of the same screen size.
I have been looking at door/window frame fixings as the long plastic plugs will surround the bolt as it goes through the plasterboard, but not sure how good these things are in terms of the pulling force they can withstand as when used with windows and doors they’re not really taking any force, just holding the window frames in place. I know the TV will be pulling on the screws in shear rather than trying to pull them out of the wall, but there will be a pulling component to some extent. I’d also use 6 instead of 4.
The only other system I saw that I think would be overkill, but i’d rather than have that and piece of mind is the resin stud system – so you drill a large hole in the wall, fill it with a resin/mortor mix, insert a huge stud, wait for it to go off and harden then attach the bracket to the studs sticking out of the wall. Anyone had any experience of this system? Cheers.
