wl – Member
Cheers for all these replies/links – some useful stuff. Although I’ve never really done it before, I like the idea of something I could stick crampons on for some winter walking.
Then you’ll need boots which are stiff enough. There are ratings B0, B1, B2, B3 which match crampon C0, C1, C2, C3
B0/C0 means no crampons – the boot simply isn’t stiff enough. You might get away with a very lightweight crampon to stop you slipping around, but you run the risk of them simply falling off as the boots flex. B1/C1 is a stiffish boot and a strap on crampon – adequate for no-technical winter walking. Those Mammuts are apparently B1 so up to your requirements. Higher grades are stiffer boots for step in and/or rigid crampons intended for more technical work – climbing, mountaineering.
