Viewing 26 posts - 1 through 26 (of 26 total)
  • VW Golf Mk5 (2008) turbo overboost problem – advice please
  • eemy
    My 2008 Golf has a turbo overboost issue. If accelerating hard up a hill in 4th gear it will lose power and go into limp mode. Switching off and switching back on again ‘fixes’ it, but clearly there is a problem.
    I took it to my local non-dealership garage yesterday, hoping it was a sensor/simple(ish) fix but the mechanic has said that a new turbo is probably the way to go. I use the garage regularly and I’m more than happy to accept what he’s saying. He’s cleared the fault codes.
    So my question is, should I ignore the problem and keep using the car to pootle back and forward to work (i.e.) will the turbo problem get worse? Or should I trade it in sharpish for something else?
    PS – I won’t try and sell it on here. Although it does have heated leather seats which are very nice.
    wolly
    Have you checked the hoses associated with the turbo for any leaks, you should here a rushing/hissing under load that would be the first place I’d look.
    eemy
    Wolly – unfortunately my car knowledge is non existent. But I don’t fancy paying many hundreds of pounds for a new turbo plus fitting if chances are the problem won’t get worse. If the likelihood is that it’ll start happening more often then I would be inclined to get another car.
    kormoran
    I had a very similar issue on an Astra tdi. Tried all the usual suggestions but never solved it
    This was exactly what I was doing, ie not driving it hard enough. I changed my job, the driving got harder and faster and the problem went away in a couple of very black clouds out the back
    Diesels eh?
    thomthumb
    i’m far from an expert but
    sounds wrong on many levels.
    Get it into a VAG specialist. can recomend one near southampton…
    i’d buy it if it’s cheap. My man ^ can definately fix it.
    garage-dweller
    If it’s one of the intercooler hoses the whoosh noise should be noticeable (certainly was on my Mondeo) and it will belch a load of soot at the same time.
    When you say it has an overboost issue is that something is that coming from fault codes or the garage?
    Does it do it in other gears?
    Turning off and on again resolving it sounds more electrical than mechanical to me.
    VW specialist or different independent for a second opinion I’d say.
    molgrips
    That sounds like bollocks.
    If the turbo works, then the turbo works. If it suddenly cuts out when there’s a fault under certain conditions, then the ECU is detecting something possibly risky and going into limp mode to protect itself.
    Given that it happens when you are accelerating hard, this is almost certainly overboost, meaning that it has detected too much boost pressure into the engine. Normally, there are these vanes in the exhaust that capture more or less exhaust gas to make the turbo spin. The engine opens them up wide when you floor it but as the revs climb and more exhaust comes out, it has to close them up a bit to avoid making too much boost pressure.
    The vanes can get oil and grimy and get gummed up, so that they don’t open and close properly and get sticky. So if the engine cannot shut them up quickly when it’s sticky, it’ll detect overboost and you’ll be in limp mode.
    Given that the car works ok the rest of the time it’s probably jsut sticky and needs cleaning. You can use a variety of spray-in cleaners to clean it up; you can get under there and wiggle it free, or you can take it off and clean it with a toothbrush.
    If you are near Cardiff I can take a look.
    enfht
    Fairly common issue with VAG turbo diesels. Could be a split hose but more likely the turbo is cloggged up inside, the vanes get coated in carbon. The standard advice is new turbo as they’re made difficult to service, ie riveted casing, but the best advice is to find a turbo specialist who’ll be happy to take the turbo apart and service as required. Definitely cheaper than a refirb or new unit. Find a VAG turbo servicing specialist, Google is your friend. There’s one in Stevenage if you’re in the south east.
    eemy
    Thanks for the offers to take a look and where specialists are – unfortunately I’m up North and all the people in the know seem to be dahn sauf.
    Only ever happened in 4th so far. I’ve got quite a sedate commute on country roads.
    Splash-man
    As others have said its gummed up games on the turbo.
    Most garages will recommend replacement of turbo.
    Had the same issue in a VW Touran.
    The wife just kept running it as she was more gentle on the throttle.
    Eventually traded it in after a couple of years of it first happening.
    shadthebad
    Random Question, where do you buy your fuel? Supermarket or branded?
    Have search on “n75 sensor faults”. It may help.
    eemy
    Splash-man, that is along the line with what I’m thinking. I know it could go catastrophically wrong, but it’s not so long ago that I had the timing belt changed and feel that the car owes me at least a few more months.
    Supermarket. I’ll look up n75 sensor faults, thanks.
    Mister-P
    Sticky vanes in the turbo sounds likely. A mate of mine has a 2.0 tdi and that would go into limp mode every so often because of that issue.
    mikeyd
    Google “mr muscle turbo”. As above, probably turbo vanes sticking.
    Fixed two VAG tdis of mine and done as a preventative measure on my current.
    Alternatively new turbo or get it cleaned by someone who knows what their doing.
    Edit: maybe try Forte Turbo cleaner, this gave one of my Tdis another 6months, although I think I messed up the gearbox by ragging it a bit too much (280k on the clock)
    nealglover
    Where in the North are you?
    I know a few people I’d recommend in North or West Yorkshire.
    jimjam
    I can’t comment on your specific issue but my B.I.L had turbo issues on his 330d which he kind of ignored until it completely failed and resulted in catastrophic damage to the engine. Many thousands to repair.
    Anyway, as abovem check the plumbing for a boost leak, check the maf and if needs be get the turbo rebuilt.
    wwaswas
    My motor home has a blow off valve that bleeds off excess turbo pressure and occasionally jams shut leading to the exact symptoms you’re seeing.
    eemy
    Near Edinburgh
    nparker
    Recently had the same problem here on a T-reg Audi A4. Read around a few websites and a few suggested the problem being that the engine wasn’t being revved enough. I was tending to change gear before 3000rpm trying not to be hard on the engine but it seems this was making it worse. The website I found (can’t remember what it was) suggested putting car into 3rd and then flooring the accelerator at 1200rpm. If it loses power, switch off and restart and then repeat the exercise. If it is still consistently losing power after the 3rd attempt then it may be the turbo is stuffed (according to what I read – I know squat about car mechanics).
    In my case second time round it was fine. Tried it a few times going up and down the A3 and discovered acceleration I had no idea existed (well for a 19 year old diesel anyway). Next thing I did was fill the tank with premium diesel. Now I regularly run the engine to 4000rpm and it is running perfectly – not had the issue in the last few hundred miles and just passed MOT without advisories. Probably blow up tomorrow..
    a11y
    Sticky vanes as others mention.
    Exact same symptoms on my 04 VW T5. Tried various turbo cleaners but nothing was effective. Ended up getting the turbo internal replaced by “the turbo guy” (google them) on south side of Glasgow. £200ish plus the removal/refitting from memory.
    molgrips
    You could try doing 80mph in 4th for an extended period of time. That might help burn it all off. Or it’s definitely worth a can of Forte turbo cleaner. Forte is supposed only to be sold to the trade but they are always selling it on on eBay.
    Andy
    Following. My 16 year old Mk4 Golf has developed same issue
    jam-bo
    You mean 70mph yeah? 😉
    nparker
    70 in 3rd.
    chickenman
    As I had something similar happen with a B5 Passat which turned out to be the boost sensor. I would pull the connecter off the boost sensor, give it a spin and see if it drives any different. sensor on my car was on the hose between the intercooler and the inlet manifold.
    mikey-simmo
    I had a Honda which shut itself down under high boost periods. Turned out it was under fueling due to a blocked fuel filter.
The topic ‘VW Golf Mk5 (2008) turbo overboost problem – advice please’ is closed to new replies.
