My current 2014 CTD (push tuned) still isn’t performing as good as I would like- I am expecting too much perhaps but I can’t get the small trail chatter vs larger hits (5/6ft?) balance right. Its on a 2014 Bandit and when I last spoke to TFTuned they recommended sticking with the shock and the Push treatment. Its better, but I want more! Before it went away it had the largest volume spacer in there- I need to dig the paperwork out to see if it was removed or not.
I will do some more reading on the Corset as I’m confused as to if its the right solution- will it change the end of the shocks travel? They suggest the need to run a higher pressure.
I will happily chat to TFTuned again just want to get a better understanding of it all!
A few options;
Back to Tftuned to tweak the Push tune.
Fit a Corset (DIY) but not sure how that will play with the current tune.
TFTuned fit the Corset and tweak tune (which means it will have had £300 spent on this shock this year..
A new shock
70-75kg in riding gear.
