There werent many in the system when I got mine about 6 weeks ago. Rides great although I havent had much time on it yet. An hour or so tweaking pressures on the trails and I had a setup I was very happy with. Shock tune seems spot on for my weight, about 170lbs.
Wire bead super tacky Minions front and rear make it hard work on the flats and ups. Super tacky in the rear is a mental spec choice IMO. Changed the rear tyre to a folding maxxpro. Also swapped the bars and stem to 800mm/60mm and the brakes to SLX. I have the 19″, the top tube is a bit high but it hasnt been a problem so far. Perfect length for me @ 6 foot. Fork is Dual Air which wasnt clear from the description but a nice bonus. Cassette is XT 11-34. No-name hubs.
Also came with a second set of linkage plates with bearings installed that let you drop rear travel to 137mm. I’ll prob never use them but was a nice surprise.
