Righto, changed the front pads and discs on my 08 plate vivaro this week. It turned into one of those jobs that leave you scratching your head wondering why i hadn’t done it myself before.
So to the rear, they are in a pretty bad way so same again but this time the discs have integrated bearings. After looking at a few videos online it seems no worse a job, just a large 34??mm bolt to undo /redo.
Has anyone done these before or a similar type with any ideas. Cheers all. oh my ABS warning light is on. Apart from it going to the garage will that reset when i have everything set up properly or does the sensor need looking at.
