Hi Hora
Our program doesn’t contain a virus, but it’s in the interests of certain claimed IT support or low end unheard of anti-virus software sellers to spread posts across forums. Outfox TV has an inbuilt uninstaller, and if you have any issues with it, we offer free support via put help desk, email below.
Please follow uninstall tips below.
Windows 8 :
a) Place your cursor on the bottom right corner of the screen until you see the sidebar come up. Click “Settings,” then click “Control Panel.”
b) Click “Programs and Features” from the Control Panel screen.
c) Scroll down through the program list until you find OutfoxTV.
If OutfoxTV appears, click on it and choose “Change” or ‘Uninstall’ to Uninstall
If you wish to remove the Application and also remove the saved browser tabs that provide a link to www.outfox.tv, ensure you select the “Remove www.outfox.tv from saved browser tab/homepage” checkbox, then click Uninstall.
Other Versions of Windows :
Use Windows Explorer to browse to c:/Program Files/OutfoxTV
If OutfoxTV appears, double click the “uninstaller” file to Uninstall
2. IF UNABLE TO FIND OUTFOXTV or the uninstaller .exe file in the above, the uninstaller must have been run previously, or the OutfoxTV folder has been deleted manually. If you recall seeing the Uninstall Success message, you can be comfortable the program has been removed. If not, THE BEST METHOD TO ENSURE THE FULL UNINSTALL ROUTINE RUNS PROPERLY, IS TO REINSTALL, THEN UNINSTALL. If the folder was deleted manually this will not have properly uninstalled the program.
We suggest you reinstall the latest version of OutfoxTV downloadable from www.outfox.tv, then RUN THE UNINSTALLER as shown in Step (1) above. This should ensure the program and all features are correctly removed. Once the uninstaller completes, please restart your computer to complete the process of folder removal.
Thank you.
Oscar
E: support@outfox.tv
