I have an internal cupboard in the house, it’s above an ensuite, so like a little mini loft space, and I’m seeing a bit of mould in there at present.
Ensuite has an extractor which is ducted up through said space, but we never really use it, so I’m sure that’s not contributing much to the problem. It’s more because the bedroom the ensuite is in is quite a cold room, and is also right at the chimney wall.
So, the obvious solution is to get a couple of vents into the loft space, and a couple into the room, but will this be enough?. Anything else I should be doing?.
I originally wanted it as a place to store bike bag, luggage etc as I don’t want to use the loft, but If I don’t act they’ll all be goosed with damp.
