A recent haze of indecision has lead me to need to ask this – like a whet tyre thread but even less interesting ….. 😡
I have a Rohloff hub that I keep meaning to get built up for use on a couple of bikes.
The plan was originally to swap out my Fortitude for a Longitude and have the Rohloff built into a Dually to match the front.
This isn’t looking like a reality at the moment due to ££, the Fortitude being a lovely ride and the fact that the Rohloff set up on the Longitude looks to be a right PITA.
Sooo
The clearance on the back of my Fortitude isn’t great and I currently run a 2.1 Prowler on a Flow (non EX) rim laced into an Alfine.
The other bike is my Skookum that should take a slightly wider tyre.
I would like to only need to build the Rohlfoff once and the reality of having a frame capable of taking a 29er+ in the rear anytime soon isn’t likely 🙁
The Flow EX seems a sensible option but the Blunt is a touch wider. Both can run tubeless (although I run tubes 😳 ), both are about the same price but importantly both could run a 3” tyre although granted not optimally.
So with you money what would you go with?
