Just about to buy my 3rd Trafic…
Ran the first one (06) to about 240000km. Eventually died from a severe snow-plough interface (I kid you not…)
Clutch cylinders went at around 120000km. This is a lot of labour to fix. Otherwise, nothing other than wear and tyre. It had a terrifying complete electrical failure one dark and snowy night while driving down a steep alpine road, but it was only a loose connection to the battery.
Second one now (2010) now on 230000km. Clutch cylinders failed at around 120000km. See a pattern there? Has had a few annoying and less than cheap issues (wiper motor, engine fan…). A year ago, it was struggling to start and at low speed. This was down to faulty/worn-out injectors. Replacing injectors is a known issue on these vans – there is a water trap which means they corrode and seize. Makes what should be a simple job very expensive. Still driving great though.
