Mapp guns get stuff cherry 🙂
Top tip don’t buy the cheapest parts you can find. It’s worth buying better quality in almost every case.
Think the first Job i did was an alternator …. Mostly because it was easier and quicker than getting the garage
Top tip would be to familiarise your self with where everything is on the van prior to the event then your not scratching about in the dirt when the time comes.
For basic servicing which is probably the easiest place to start. Try and see if there’s a YouTube video for your vehicle.
But remember be methodical don’t rush and always double check.
Don’t be that guy that sticks oil in without a sump plug or forgetting to change the oil filter before hand.
Or worse….the guy who starts his engine with the oil out…..and it’s happened to a mate of mine.
