• This topic is empty.
Viewing 1 post (of 1 total)
  • van rough as a badger's behind on cold start
  • walla24
    Transit connect 2005 1.8 petrol/LPG
    Idles irregularly (around idle speed but then dips below, comes back to idle, dips below) and will cut out from ‘cold’ start, fine if you rev past 3000 or drive for a couple minutes then will idle/drive spot on.
    Reasonably recent plugs, ht leads (cheapy ones) and that box of frogs that makes the sparks before the leads
    Have had to helicoil one of the spark plugs recently…was fine initially but coincidence?
The topic ‘van rough as a badger's behind on cold start’ is closed to new replies.
