I have a new van to me, a FIAT scudo, and recently the engine management light came on and “ANTI POLLUTION FAULT” came on on the LCD screen. I plugged in my basic code reader and it listed two error codes. P0100 “MAF circuit malfunction” and P3008. This brings up nothing on google for FIAT but on a VW it brings up “Camshaft position (CMP) sensor – signal limit exceeded”, this FIAT has bosch fuel system which I think VW frequently have which to me would raise the chances that this is the same fault code? I’m guessing signal limit exceeded refers to the rate at which the camshaft signal is coming in? I would expect a camshaft sensor to be a optical or magnetic quadrature encoder. Perhaps unrelated but when cold it is easy to stall and requires more than usual revs. No smoke. No limp home mode.
I removed the MAF and it looks new and clean as if it has been relatively recently replaced. While I was there I also opened up the air filter to give it a blow though and it was missing. Do you think this may have been left out on purpose? The MAF would sense more air and cut back the fuel but I can’t see how that would help with anything?
My initial thoughts when the the “ANTI POLLUTION FAULT” text came up where ERG or DPF. Googling suggests DPF but how would this though up a MAF error? Surely a blocked DPF would result in too much back pressure on the exhaust side but that can’t effect the suction side can it?
Anyone have any thoughts. Off to by a air filter tomorrow.
