ok have been on holidays and all sorts so van hasnt turned a wheel
need to do the rear wheel cylinders atm as well so just ordering up
any reason to change the strutt top mount – do these get damaged regular or is it likely just to need the bearing – euro car parts sells both – the top mount inc bearing is 55 quid and the bearing alone is 13 quid.
i had it out when i changed the spring but as you cannot see the other side without removing it i do not know if it has been damaged or not.
brickman – if you can change these bearings in an hour a side ill eat my hat – notoriously difficult to get the front suspension off em , you cant use conventional spring compressors as the arch liner does not permit. My mechanic buddy did give me some tips and tricks on how to remove em without dumping all your gear box oil over the drive as per haynes manual instructions
