We had a Vax cylinder, after which we vowed never to get another Vax. We then had a Samsung cylinder which was really good, then a Hoover upright which went back in 48hrs as its long stretchy hose was useless, as soon as you turned it on the suction pulled the hose so hard the upright fell over, also the beater bar stayed on even when the machine was ‘parked’ so you had to manually raise the height when using the tools otherwise it knackers the carpet, the final straw was it snapped its belt the second time it was used.
Ended up going back on my word and getting a Vax upright, much better, stretchy hose stays stretched when the machine is on, beater bar turns off when upright and you can turn it off manually as well so dirt doesn’t get flicked around the kitchen, and its lower profile than the hoover so fits under all the furniture like the cylinders used to. Only problem is the hose keeps falling off but I think the stickers all over it say don’t return to the shop, they will sort any problems…
