Viewing 4 posts - 1 through 4 (of 4 total)
  • V-brake retro fitting to my balance bike
  • stevied
    So, thinking about it, I probably should have put some mounts on the frame I made to fit some brakes..
    I’ve now got a set of Deore LX and am going to make some adaptors to fit over the swingarm to mount them on.
    I remember from having V’s that the mounting has 3 positions to locate the tensioner pin but was wondering if I would really need 3 as I can’t check the angles.
    Also, can I fit shorter length pads as the standard ones are too long and will foul on the tyre due to the small wheel size?
    Steve
    cyclistm
    I’ve never mounted v brakes other than in the middle hole. I think the other holes were more useful for cantis
    Shorter pads will be fine
    JoeG
    You might want to read up on some of the canti brake stuff on sheldonbrown.com
    This and other stuff as well.
    Edric64
The topic ‘V-brake retro fitting to my balance bike’ is closed to new replies.
