Ha, I work for AkzoNobel (Sikkens brand owners) in a different division. All views are my own and in no way represent professional advice or AkzoNobel!
I was playing in a different chemistry but the same principles apply. To be honest, I don’t think a normal hand held torch is going to cut it. The TDS says a 400W UV LED or a UV HID lamp. Pros and cons to each but either is a fairly hefty industrial unit, not a torch. What is a bike light, about 5W? There are also different wavelengths to consider but as I alluded to above there are only certain options and last I was aware everyone was trying to move towards the visible end because it is safer – most torches will just be the cheapest.
They do mention
R100 LED UVA
but it looks expensive.
UV HIDs are cheaper I think but the bulbs don’t last all that long and if my memory is correct they are a little more hazardous in that they cover a broader spectrum of radiation. Still not as bad as the sun if I remember but work place rules are different to normal life rules.
Biggest UV light that are available are those used in clubs, bars etc. but they are decorative rather than industrial. Wouldn’t know the output or the wavelength and I certainly wouldn’t fancy using one where I was also using solvent which I guess you are?
If you mess up the drying/cure it will have knock on effects. IT may look alright for a while but it could deteriorate or fail in other ways sooner than it would normally do.
I’d suggest dropping customer service a line. They will have looked at a few options and will probably be able to point you in the direction of a few suppliers at different price points. Buy the wrong thing and you’ll be throwing money away or creating problems for yourself later.
http://www.sikkensvr.com/en/contact
