Has anyone got any experience of this? Sounds like bollox to me it let me know if you have please?
It’s called DLM – dynamic line management. Using a series of algorithms at the network level factors line “noise” on the line, distance from exchange, etc. are used to balance speed vs reliability. Every ISP uses it – either built in house or bought from a third party.
I called them and they said it was because the router was not plugged into the main bt socket
All ADSL routers work best in the main BT socket. Otherwise, you are the mercy of internal house wiring, which the ISP/BT Openreach have no control over. Unscrew the front of the main socket, and there is another “test” socket behind it. Plug the router into that and leave it switched on.
The other problem you may have, after all the technical issues, is that Utility Warehouse use the Talk Talk equipment and support structure. They are at the mercy of Talk Yalk when it becomes an equipment problem at the exchange.
Specifically it’s TalkTalk Business, the B2B/wholesale business of TalkTalk (i.e. pretty much autonomous from the TalkTalk retail brand). However, the customer service, billing etc. remains with Utility Warehouse.
My guess? This is to do with a bunch of other factors, and who operates the underlying network will be way down the list.
