My 9spd drivetrain is worn out, and I’m tempted to go to a 2×11 speed set-up.
The 11spd XT groupset has some strange ratios – only 10t difference in chainring size, but the smallest cassette is 11-40. This seams to have a big range available at the the back, and a lot of overlap in the two sprockets at the front.
I already have an XT M785 chainset with 24t & and 38t rings, and I think if this was matched to a close ratio 11spd cassette (say 11-36) then I’d have my ideal set-up.
I know that 11spd road cassettes use a different, longer freehub body. Is there a 6-bolt disc compatible hub with 135mm OLD that means I could use one on an MTB? Would this work with MTB shifters and mech (probably XT)?
Alternatively, is there an narrow range XD driver cassette compatible with an MTB wheel?
