should work, however, is it worth the hassle when adapter kits are quite cheap (having just recommended someone make theri own rather than buy one, i shall punch my self in the crotch!)
You will need spacers, I'm sure I read about someone using a piece of pipe for this, I suppose it would work in theory but i Prefer a tidy finish!
My only concerns with using a cassette ring would be strenght (as in how much does it gain from being attached to other rings)
ramping (without a mech for tension will the teeth be a bit shallow?)
best bet, try it, see if it works but be prepared to fit a shop bought one if, like me you have no mechanical skills!
