Viewing 27 posts - 1 through 27 (of 27 total)
  • Uses for spare carpet
  • IHN
    I’ve got loads in the loft from multiple previous recarpetings. Anything I can do with it instead of just chucking it in the tip?
    thomthumb
    carpet the garage.
    make a wig/ merkin
    soma_rich
    line the shed/garge/bike fettling corner?
    The garage has already had a bike-fettling makeover, I painted the floor with garage floor paint.
    theotherjonv
    open up a body disposal business.
    davey_clayton
    use it to scale a barbed-wire fence
    chakaping
    Roll it up and keep it in the loft until you move?
    I’ve used bits to cover ground and keep weeds down before, but apparently this may not be a good idea due to chemicals in the carpet leeching out.
    djglover
    build some dirt jumps and carpet them?
    druidh
    Stick a couple of bits in the boot of your car. If you get stuck in snow, a bit of carpet under each of the driving wheels will often give you enough traction to get under way.
    chakaping
    That’s a good one, and you can use them to stand on while getting changed in the car park too.
    Ah, changing mat, I like it.
    MrNutt
    make a tabbard!!
    frenchie
    Warming the soil and supressing weeds in the garden/allotment. Put on freecycle.
    falkirk_mark
    used mine in the car boot for chucking dirty gear on top (mtb gear dirty dog,stuff for tip)Also if working under car put some down on ground to keep warmer /clean
    corroded
    A merkin?
    Macinblack
    Glue a piece to your chin, makes you look rugged.
    CountZero
    I use a strip under my bike stand. Helps stop small items bouncing and disappearing between the flagstones on the patio. More comfortable to kneel on, too.
    johnhoo
    if it’s about 6 foot square you could put one of these on top of it:
    thomthumb
    merkin
    Stoner
    line the shed with it as a cheap form of insulation
    mrmo
    carpet country lanes? helps with the traction on ice.
    skidartist
    If they are a reasonable size see if there are any local charities/ recycling initiatives like Spuce here in Glasgow. There are places that can run an edging round small sections of carpet to make rugs too.
    MartynS
    is there enough to roll yourself up in it, then when guests arrive, have it dramatically unrolled so you end up at their feet?
    johnhoo
    cut small squares out & attach them to your feet. Then wherever you go, there’s carpet underfoot
    MrNutt
    dig a hole in your garden and live the whole of next week as a trapdoor spider?
    skidartist
    Dig a hole in you garden, or lift some floorboards, lay the carpet over it and wait for something hilarious to happen. Keep a camcorder handy
    colande
    pond liner protecter
The topic ‘Uses for spare carpet’ is closed to new replies.
