Mine snapped. fortunately while I wa trying to tighten them up in my flat, rather than on the trail in the middle of nowhere.
never again.
See the really old USE seatposts seemed to go on forever as long as you remembered they were XC posts. My carbon alien snapped after a month, the Alien heads are great once you get them into position, but if there’s any adjustment to be done it involved loosening the bolts off all the way then smacking the shit out of it with a rock.
The cyclops head was supposed to solve all the problems. Unfortunately, instead of gripping the shaft of the bolt, meaning that undoing it would splay the sections of the alien head apart, thus loosening it’s grip, it slid along the shaft, meaning that you just had a slightly larger bolt to smack the shit out of with a rock.
The SUB fork is great too. Works exactly how it should. Apart from the internals heating up so much that you go from just enough damping to syrup forks if you go over anything more than stutter bumps. I ended up taking a small drill bit to my damper bits of plastic, just to get the thing working OK. It was fine if you rely on friction to damp it.
grumble grumble…..
