…let me know your thoughts
Well since you ask. You need to be much more ruthless with the editing – take out all the boring bits – all the start/end of trails stuff should go and although you’ve used a different camera angle – looking at you helmet for 30s is 27 seconds too long 😀
I’ve never ridden swinley (live in a different country) but it looks like you’ve used the same couple of trails over and over. Pick the best bit of each run and edit into one run for each trail. You could edit that down to about 1 min or so and it would look much better (with appropriate music – or none).
The trails look to have some nice berms and jumps scattered about – use the gopro like a handheld to try and capture these – everything looks flat with onboard footage. I made a couple of mounts to attach to trees and the ground for this type of thing.
Here’s one I made last year using the mounts and taking turns holding the camera.
[video]http://www.youtube.com/watch?v=Vjw95_aR4KE&feature=share&list=UUPvti4d0R4E6J7p8wPSPmaQ[/video]
