‘lol noob you can’t change forks your bikes crap.’ kinda approach I felt from others…
think youre being oversensitive, I havent read any of that, just people asking if you knew what you wanted, more travel or better suspension action? Asking a question then insulting the respondents is rarely productive.
Marz= tend to be heavier, and require essentially no servicing. Had a tough couple of years and lost their previously strong rep, so avoid 2007-2009 era, and is also why they are often cheap new (as most people have stayed away).
RS are pretty strong across-the-board, cheaper models may have a simpler damper, or steel stanchions/steerers compared to more expensive models. Reliable and easy to service.
Fox; expensive, easy to service but need it about every 20minutes or the stanchions wear out.
(I own all three brands, before it descends into a Fox vs RS war…)
I’d look for a Rockshox reduced from On-One, JeJames, CRC etc. Many are spaced internally so a 100mm fork can be changed to 120 and vice versa.
A bit over budget but a quality fork.
http://www.jejamescycles.co.uk/rockshox-reba-race-dual-air0mm-black-red-id53556.html
much cheaper options here
http://www.on-one.co.uk/c/q/forks
edit: not when I’d started typing it he hadnt….
