Rapid rise… It just works so well. Yes you have to reprogram your brain a little but being able to drop a gear or two when powering up a hill out of the saddle is sooo worth it.
I never want to go back, if only they did a 10 speed.
+1, I twatted my last one on a rock 🙁
It only makes sense if you use a thumb push for both up and down shifts, otherwise you can’t easily shift to a lower gear while braking (unless you brake with your middle finger and shift with your index finger)
SRAM shifters solve this nicely, just a shame their mechs are cheese.
It’s taking me ages to get my head arround shimano shifters again, they’re just not right, and ‘dual release’ is useless as the lever pivots the wrong way so pushing with a thumb is just awquard.
TJ would have a point about motorcycle bars if they were’t either practicaly solid with a cross brace (MX bars) compared to MTB bars to gain some stiffness or clip-ons 9your not going to make a 8″ long 22mm tube bend however much you twist it).
Remeber people buy carbon bars partly for the flex in them – and youdo not put huge loadins in steering input into bars
No, I bought them:
* becasue they weighed less than 200g
* looked cool
* absorbed some vivration, theres a difference between a flexy material (Ti) and one that dampens the oscilations. Ride a bike with a long Ti seatpost and you’ll see the difference, it’s posile to make the post oscilate in time with your pedaling, carbon posts will flex just as much (if you build them to) but they don’t give that energy back so it doesn’t bob.
motorcycles put far more stress thru thier bars and use skinnier ones.
Find some 200g MX bars (not that i’d trust my wisers on an MX bike, but seeing as it’s still me twisting them there’s no obvious reason not to). I’ve never ridden MX but I put a lot more force through the bars on push bikes than I do road motorbikes, think of all the heaving you do standing up and sprinting, put that much force into a motorbike and you’d be in a hedge.
Back on topic:
Do old slide on grips count as a standard? I’ve recently gone back to foam slide on grips after years of lockons and it’s a revelation in comfort.
