Apart from wheels, I do all my own mechanical work.
I had a Cyclus headset press that I used for about three year – it cost £35 at the time (2007) but I see they’re now £50+.
Unfortunately, I somehow managed to strip the threads on the press and looked at replacement options. £50+ seems like a lot for what they are, so I gave a £4 “homemade” eBay press a go recently:
I’m happy to report that it did the job just fine. I really can’t see any reason to buy a more expensive one, unless you use your press much more often that the average home mechanic.
So the Unior Headset press and other tools I ordered arrived today and very impressed with them,I have already used the Headset press to fit a 1″Headset to a older roadbike I’m refurbishing and it was a doddle.
Even more impressed when you consider the Press,Pedal Spanner and Chain Tool came to £78 inc Shipping from the Czech Republic less than the Press on its own from Halfords.
curiousyellow – how much did it cost you with the postage? I’m certainly tempted, I’ve made a home made press but found it struggles with the initial line up and ended up using the rubber mallet to start it off.
Took about 5 days for the postage which I don’t think is unreasonable especially with the cost savings involved.
Postage for me was $15.99 which was for a Pedal wrench,Chain Tool and the Headset press was is a couple of Kilos on its own.
The headset press is definetly a good bit of kit I don’t know how it compares to others but makes fitting a doddle.
I have used a mallet and block of wood in the past and also a home made creation with threaded bar,all seem to work to varying degrees but the proper tool is much easier and more professional and for me as I intend to do more bikebuilding and repair work is a worthy investment.
