Both aluminium threaded inserts on my Trance Advanced rocker link (carbon) appear to have come unbonded from the carbon. These are the bits secure the topmost rear triangle bearings to the rocker link. I had wondered what that creaking noise was!
I’ve managed to – easily – pop both of these threaded insets out and see that everything looks pretty much okay inside. The metal also inserts appear fine and dandy too.
It should be a pretty straight fix to carefully epoxy these back in?
1) If doing this myself which uber-hardcore pro epoxy for carbon would be best to use? (I’m guessing the stuff at Poundland probably won’t cut it!)
2) Even though it’s just a rocker link, would I be best off sending this part to a carbon frame repairer – to get it professionally fixed?
3) Is there any remote chance that these Alu threaded inserts are not actually supposed to be bonded to the rocker? (Though I can’t see how!)
Thanks! 🙂
