As others have said – best left well alone IMO
I'm not stupid. Really, I'm not. You just think I am because you aren't really understanding what I am getting at, and you therefore assume I am thick and going to do something really brainless. I like to fix things, but bearing in mind the above I am not going to bugger up my forks.
you dont have rings sealing your pistons so honing wont help.
Ehh? I am not going to bloody well HONE them, I mentioned that it was a similar idea!
Mangle your forks with emory paper if you want but you'll wish you hadn't.
This entire thread exists because emery paper is EXACTLY WHAT I DO NOT WANT TO USE! Good god you people aren't half thick sometimes! Try reading the thread properly! 🙂
If this method worked why isn't it done by anybody as standard?
It is, I think – by DT as mentioned above. And shiny metal isn't all that smooth – quite possibly rougher than the shiny coating on my stanchions.
The forks currently are very smooth in movement, but what happens is that after a few seconds of non-movement they stick, and stop responding to small bumps until you hit something bigger. It's almost as if.. there's no oil film between the seals and the stanchions. Now, if only I could find a way of getting oil to stick to the stanchions it would be much nicer. Maybe a very slightly rougher surface finish would help?
