Spent 4 hours last night on a mates bike trying to index tge front mech.
Now I have a reasonable experience with bikes and have no problems setting up MTB's and road bikes normally.
Setup is a Bonty X lite double Cyclocross crankset/GXP BB. STI = Ultegra 6600 front mech = Campag.
He fell off and sracped and sl bent the left drop and shifter. The inside down shift is a bit graunchy.
I cannot get to a position where the chain will shift from teh inner chainring to the outer if on higher than sprocket 4 and if I set the outer limiter so it will when on spocket 1 (11t) is jumps off outside. I have started from scratch 3 times and followed my own setup and teh ultegra instructions (which are basically the same)
Do the STW hive think it it a busted lever? The mech, seat tube roller cable redirector and cables all seem fine when examined.
He also said it has never shifted quite right from when he had it new 5 months ago. Its a cyclocross frmae with 68mm BB. The bonty crankset seems setup right with one spacer as without the spacer the crank wont bolt up tight enough? I gave up at 9pm last night.
