Viewing 2 posts - 1 through 2 (of 2 total)
  • Ultegra front mech problem – low adjuster seized
  • cakefest
    Getting some front mech cage rub while in low-low on my Ultegra mech. The Low adjuster has seized and I can’t turn it. Have tried WD40 and chain lube to try to free it – the blighter just won’t turn either way.
    Should I live with the rub – only in low-low, or is there something I can do about it?
    ndthornton
    I have the same problem but with a cheapo Tiagra mech, totally seized and I haven’t found a solution. Helpful I know lol
    Mine is worse actually – it started with chain rub but when I last replaced chain + rings I discovered I now cant shift the mech far enough to get off the biggest ring.
    I was going to buy a new one but my performance has improved so much by staying in the big ring Iv decided not to bother.
    Moral – cheap, old, broken parts make you go faster than shiny new ones!
The topic ‘Ultegra front mech problem – low adjuster seized’ is closed to new replies.
