so here goes, my LBS which i use regularly along with some online purchasing recently (last September)built me a road bike.
I supplied frame fork and wheels they supplied drivetrain etc.
All going well until recently when the DI2 ultegra rear mech slammed down the block from middway and refused to shift. We limped home using two gears (front shift only) and dropped it in for a check up. Software update done and no obvious fault we were reunited and happy again.
Used the bike 3 days later for an hour or so hills session and no issues.
Following on next time it was ridden a strange and dangerous occurence.
Following a failed upshift, the mech appeared to drop to the bottom of the cassette again, this time it was in the small ring upfront and i think that it couldnt cope with the instantaneous chain extension. This caused the chain to jam and everything locked up. This ripped off the mech hanger and damaged the frame, luckily i had looked down to see the rear mech bunched up and braked hard so saving the wheel.
Firstly any similar issues heard of with Ulegra DI2, secondly what do you think the diagnosis was from LBS?
Will be back on thread after an hour or so to enlighten
