Viewing 3 posts - 1 through 3 (of 3 total)
  • Ultegra 6700 cranks
  • cchris2lou
    Bought a second hand set and end cap plastic bolt is missing . I have fitted them making sure there is no play , but can I use them without that bolt ?
    dont fancy wrecking the cranks .
    thanks
    crashtestmonkey
    its like a stem top cap, there to provide preload before you actually tighten up the pinch bolts (which actually do the securing). Shimano cranks have a “fail safe” plate that sits in the crank arm and engages with a hole in the spindle to stop it falling off.
    So yes you can use them without the end cap.
    cchris2lou
    thanks ,but I ll order one anyway .
The topic ‘Ultegra 6700 cranks’ is closed to new replies.
