The unridden bit that Mike refers too has become quite a bit more washed out since I first rode it. If it is the same bit, it’s right hand steep drop where I had to do a bit of hopping to manhandle the bike down it. I got past the hard bit then promptly hooked up and failed on the easy bit at the bottom. Garr! I last rode it in October on a fine sunny day and the trail had definitely become a bit more washed out in places.
Great ride, any bike will do as long as your brakes are good I reckon.
If you do it, climb back up on the fireroad and do the steep Doups descent. It’s silly steep but fun and 100% rideable if you are happy on steep stuff. It makes me giggle every time I ride it.
Oh and there are two scree lines off of Skiddaw. Both are excellent! The second one is parallel with the main path but not so obvious.
