Viewing 11 posts - 1 through 11 (of 11 total)
  • Uh Oh, new superstar rotor issue?
  • kimbers
    feels rough on one side, smooth on the other
    havent fitted it yet ………
    will it ride ok?
    wwaswas
    if it doesn’t can I have your bike?
    nealy
    Just use the smooth side
    trail_rat
    its a punched rotor then
    itll smooth off quick.
    soobalias
    how “rough”
    cyclistm
    just use one pad in the caliper
    theflatboy
    have you got it the right way round? smooth side should be facing out on the front, in on the back.
    HoratioHufnagel
    won’t it make the bike go in circles when you brake?
    firestarter
    I’ve just got a hope floater with a wobble and its actually egg shaped one section is at least a mil bigger and I’ve had to space out the caliper 🙁 not worth the hassle of sending back tho
    nicko74
    will it ride ok?
    No. Do you have a will?
    kimbers
    well been for a ride and you know what.
    it worked just fine its one of them saw tooth numbers but its the wrong direction compared to the hope one on the rear , now will it work backwards ?
The topic ‘Uh Oh, new superstar rotor issue?’ is closed to new replies.
