Re-installing just to fix the wireless seems pretty overkill! sorry if you have already tried this/it's obvious but…
I'm not at a linux box at the moment but from memory, have you tried something like 'ifup -a'? To try to bring it back up.
Also if you get something like hwinfo (sudo apt-get install hwinfo) you can see whether it still recognises it? This should also give you the actual chipset so you can try to find the appropriate driver. Once you know what to search for there are 100s of Linux forums and there is quite likely to already be a how to.
I would definitely try to fix it rather than re-install, especially as if you re-install with Karmic and it still doesn't work you are no better off.
Actually, as a thought, restart it, re-run the update manager and the hardware drivers GUI thing, and turn it off and on again if you havent already. It might be that the update shut it down and never brought it back up?
Hope some of this is of use?
Tom
